I make jest few test with my ecusafe over this kinds of ecus and work good - just tests to see what will happened and all is fine but manual off is the rigt way .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
problem si they remove DTCs...next problem the car has. u cant diag. manual swtich leaves DTCs on but requires all sensors working and conected.
if not the case..DTCs must be individually erased not entire index table!
yep this is right mate - like always
Info on pm
he be ok now.
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
volta and ecusafe is on top in italy...classicaly stuppidity...need shit,we can do it....
why you people continue to use VOLTA,ECUSAFE programs??? dont you realize they dont work good?!
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
EcuSafe only work good Peugeot/Citroen EDC15, EDC16 only switch manually.
