    May 2012
    Default Skybox f5 reboots constant when LNB feed connected
    Hi guys
    I updated my box yesterday with latest channel plan and it got stuck on load
    reflashed it with rs232
    now soon as I connect the LNB it's rebooting no shorts on the cable as I've tested it
    any ideas or suggestions
    thx in advance
    how did you test ?
    P&D's Avatar
    My thoughts as well ???
    If the box boots ok without the cable attached then its most prob the cable or the LNB
    or the settings on the box might be wrong
    But most of the problem you say are caused by the outer wire touching the inner wire on the feed
    Maybe a faulty tuner shorting out just a thought
    Maybe someone has had the same prob ??
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by figaros4sale View Post
    Hi guys
    thx in advance
    Does it reboot at LO97?
    This could indicate that you have reflashed with the wrong firmware.
    May 2012
    I tested for a short with a multimeter send have tried smother box on the end of it works no problem it goes all the way to 100 when booting so I assume it's the correct firmware
    box is labeled as a skybox no openbox f5s
    I say the cable I had same problem
