Results 1 to 4 of 4
    Aug 2014
    Default need little help with cloud ibox 3
    hi guys my vu box took a dump and died so went and got a cloud ibox 3 after reading all day i havent a clue so hopefully some 1 can shed some light on this for me,booted box it has open pli 4 installed i really want blackhole as thats what i had on my other box so can navigate easily, I took the top off the box to see if it was a clone or a clone of a clone pics
    0.jpg1.jpg2.jpg so was wanting to install blackhole but i have no idea if i can do this also only have a 16gb flash drive i used on my vu box really dont wanna break the box as it was a rush decision to get as wife was doing head in didnt know it would be so difficult if some 1 would be kind enough to clear up if i can install blackhole that would be great and thanks buds
    Jul 2008
    Mate i "think" your box is an original and if so the images on the cloud ibox net should work fine. If you bought it from air digital then it should defo be an original although all of these boxes are a clone of some sort or another. You can check to see if you have the updated bootloader via Telnet if that helps. Telnet to your box and use this command
    cat /proc/cpuinfo (Thanks to Ferret)
    If the CPU is 750 MHz you should be ok
    I dont use blackhole though so cant help on that i`m afraid but if it is an original they are on the cloud net site.
    Good luck
    use open pli better image I think
    Aug 2014
    i have open pli 4 installed at minute and i dont like i have a vu+solo and thats got blackhole i love the image its very user friendly and yeah my cpu is 751.518 just confused as to update the bootloader or not going to borrow a pc with an rs22 port on and read that it may become more clearer thnks buds
    All fixed out it was an original box with original tuner and now successfully running blackhole 2.1.1 thanks guys
