Results 1 to 4 of 4
Hybrid View
    Aug 2014
    Default Skybox f5s freezing when LNb connected
    Hi all
    Really need help now, my skybox freezes as soon as LNb cable is fitted, it is not the cable as I have tried in 3 of my friends houses with the same issue. I have tried to delete the constant.cw files as I was told it may be corrupt, however I am not sure the correct way to do this can any one give me a step by step guide.
    Jul 2013
    N.Ireland
    There is a thread on this somewhere. If you look at my previous posts you'll find it as I had this problem, I'm on my mobile at moment so can't check back.
    The solution was to blank a few files and flash old firmware then flash new.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by Colin070179 View Post
    Hi all
    Start reading from post #65 in this thread:-
    http://www.digital-kaos.co.uk/forums...56/index5.html
    P&D's Avatar
    May 2010
    Hi all
    try a firmware update ?
    or it could be a faulty box
