Best way be found customer with Tech2 and update ecu software.
yes...but i must find a dealer that can do a pleasure to me :-(
Only tech2 or passthrough device can do this on psg16
X17 can do read-write-cks without problem.
Real read, not virtual.
Br.
Galletto have virtual read for this ECU. What prevent you to use it?
Regards!
I tested with Carprog 4.01 psg16 read e write link: Opel PSG16 diesel pump by OBDII - read/change mileage, read PIN, reset ECU. look here.
you read eeprom , it's not ecu file
BUt read is from OBD plug or from ecu pinout?
carprog can read OBD ,but it is immo data only - it is not ECU calibration data file.
