Results 1 to 4 of 4
    Jun 2009
    Default audio description
    hi all jr_419
    have just reloaded the pli jade3 image but it seems i have audio description on some channels is it possible to turn this off thanks jr_419
    Mar 2009
    Use the search option my friend, theres the audio button on your remote toggle between the 2 options after pressing it, should remove the audio desc. Hope this helps
    Member moselep's Avatar
    May 2009
    Nottingham
    Default To make English Audio of channel
    To make English Audio of channel as default setting do this
    1. Go to Web Interface (type IP of Dreambox in your internet browser)
    2. Click on Config
    3. Then click on Settings
    4. Find where there is Audio Channels Priority and paste this in box found just under
    English#Englisch#dos#haa#qaa#org#ORY
    5. Reboot from remote control
    Hope this helps, did for me
    Jun 2009
    hi all and thanks for the replys did find the settings on the remote not sure if it has done the job thou but should have done if not will try what mose has said thanks all jr_419
