For this ECU there is the dpf switch off
with Volta work?
Volta erases DTC area
Dpf off by switch off. For you. Pass in PM
Reset dpf values before writing file.
steveeprom (1st September, 2014)
Thanks you I will try
I test the file but the car has black smoke BEFORE AND after dpf off
Do you have reset the dpf values and made the substitution of dpf by diagnostic tool?
Yes before dpf file i do with vcds (replace the dpf)
The dpf is physically removed?
But "DPF off" does not mean there will be no black smoke!
"DPF off" mean - no regeneration, no limp mode with errors related to too much soot content e.t.c.
If this car have black smoke behind, check for bad turbo, or air leak between turbo and air inlet of the engine.
And finally, stop do this "DPF off" all the time... the problem isn't there always!
Regards!
drewdom (13th September, 2016), stanislav georgiev (15th September, 2016)
I agree with you but ,I am not do DPF of all the time, I do only when is necessary ,to do like you said. "DPF off" mean - no regeneration, no limp mode with errors related to too much soot content e.t.c. Thanks
I need DPF off and remove DTC P1958 skoda superb year 2008-9 ecu EDC16.
SW: 1037395411
Engine: R4 2,0L EDC
SW upg.: 03G906021QP 2893
Here file for You cs done:
Please dear members push the button if my work was helpfull!
And reputation button(star)
