Results 1 to 3 of 3
    DK Veteran ganker69's Avatar
    Apr 2013
    Default A6 3.0TDI QUATTRO DPF OFF
    Hello I have a6 2006 3.0tdi quattro, if I make dpf off trough ecu safe, car stays in limp mode - no fault found and measuring blocks seems to be ok, even turbocharger controller working perfectly
    can someone try to make dpf off file for me
    a6 3.0tdi.zip
    Jun 2012
    For you. Test and report. Reset dpf parameters before writing the file. Pass in PM
  3. The Following User Says Thank You to cawadany For This Useful Post:
    ganker69 (1st September, 2014)
    Apr 2013
    thank you mate, I solved problem, mechanics havent drilled hole well, a litle piece of dpf was blocking the hole they have made
