after programming the ecu, this vehicle need to code using mbstar too
Please could you help with good dpf off for 2008 MB Sprinter
I have ecusafe but no good for sprinter.
Please see attached. Please help. Thanks in advance.
sprinter 1037391212 orig.rar
This file have 6 month?s age, are you sure you need dpf-off or just find this file and whant learn the solution?
I have had a bad experience with Fly ....
Sorry for incorrect date, my laptops date is wrong due to certain software installed.
File and request is genuine, please help.
What coding needs to be done afterwards?
No need coding. Disabling DPF is enought only in flash modification. No more, regeneration, no more soot mass. No need sensors also.
noone will help?
yeah i didnt knew about ecusafe and coding....
i have a solution with or without o2 sensors, hat needs no coding
try and report,pass PM.
disconnect connector from temperatur sensof and sensor diff.pressure
Best regards Eddy
LOL........
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
Yes if you whant to destroy engine use ecusafe
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
if senzors are ok just good dpf off file and reset dpf nothing more
