Hi, can you advise me which tool you choose, Ford VCM IDS Ford or VCM2? Thank you
VCM 2 is required for latest models. It is also backwards compatible.
there is still a difference in the price, and what function, ECU programming and so? thank you
Ecu programming is actually a subscription service you need to purchase separately from Ford. Its cheap if you do a lot of Ford ECU programming. It also gives access to as-built data.
For the price/functionality I'd get VCM 2. You will end up buying both if you don't.![]()
what about the hardware of VCM 2 clone ?
it is better than VCM ? because i have problems with my VCM
Vcm very good tool for it's price up to IDS v75 you don't need to register it nor go online for programming, all calibrations (up to 2013)on DVD.
You will not be able to do newest Ford's like new Ford Focus III, Mondeo V, Kuga II from 2013.
If original machine, recommend vcm ids, otherwise vcm ii, clone vcm ids very bad quality
The question has VCM 2 programming function? Sellers says that yes ... thank you
anyone can say from which seller i can buy good quality VCM2 clone?
What is a price of online programing in ori?
If i have clone VCM 2 will i be able to change parameters in ford focus mk3 from 140 to 163 hp? And program PCM/ECU if as you said its online?
>>Genuine Winols, Swiftec, Ktag, Flex, x17<<
>Diagnostic, Chiptuning, Dashbord<
VCM 2 Pro includes VCM2 IDS software, UCDS software and FORSCAN software all functions, Can do online programming without license,just input into username and password.
Note: VCM 2 Pro includes VCM2 IDS, UCDS and FORSCAN all functions.
Support ford + mazda + new lincoln. Update freely forever.
