Results 1 to 7 of 7
    Jun 2013
    Lithuania
    Default Chrysler PT Cruiser 2.2 CRD Hot Start
    Hello, I have Chrysler PT Cruiser 2.2 CRD 110 kW with hot start problem. It has EDC16C2 ecm. I tried to read with MPPS directly Chrysler Pt Cruiser 2.2 CRD but it gave me error, so I tried Mercedes Benz A200 EDC16C2 and it have readed succesfully, so I supose it should work?
    Could anyone could give me advice I have tried to find map like in this guide (https://sites.google.com/site/vagecumap/hot-start-fix), but I couldn't. Could anyone check and help me out? Also I would like to know if there will be no problems if I have readed dump as MB A200?
    I attach my dump: EDC 16C2 Cruiser.zip
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Hello!
    I've never seen such problem like "hot start" on EDC16 Common Rail system.
    I suggest you to check rail pressure while crank the engine...
    Regards!
    Babos's Avatar
    Mar 2012
    There can be problem in fuel system!
    Check all conection some where you can see fuel go out!
    Jun 2013
    Lithuania
    Thank you for your reply, yes, there are no programming hot start problem on this vehicles. Howerver the problem exists, the pressure is fine while cranking 320-350 bar, injectors were tested and fine, compression, timing - good. Everything is good, no faul codes. When I try to crank the car for example: at 30 Celcius temperature, the injection quantity starts from 35 mg and the car wont start, the ecu starts to dose more fuel 34,40,50,60,65 mg and it starts...
    When I disconnect temperature sensor the ecu "sees" -40 Celcius temperature, the injection quantity is 80 mg and the car starts fine.
    I dont know what to look for, everything is fine... (yes temperature, injectors (tested in few places with injected quantity and pressure), compression etc...) I tried to find and modify the start map, but still can't find it. Could anyone tell me location off it? I attach my dump: ext.zip
    Babos's Avatar
    Mar 2012
    Here your file.
    Best regards.
  6. The Following User Says Thank You to Babos For This Useful Post:
    Milicija (8th September, 2014)
    Jun 2013
    Lithuania
    Thank you very much!, I will test and report
    Jun 2013
    Lithuania
    Thanks for babos, your dump works and now it starts to dose from 65 mg !
