Where can I get a "NULL MODEM CABLE" from?
I need one to reflash my box which won't boot.
What type will I need?
USB to Serial Null Modem Cable EuroVox Upgrade Lead on eBay (end time 10-Jul-09 16:16:12 BST)
ebay seems to be a good place ive ordered one from above link
Or go to your local maplins store..they always have em in stock..
if you have a serial port on your PC then get a direct connection one like this..
Null Modem 1
If your PC only has USB then use this in conjunction with the above lead..
Null Modem USB Adapter
OK I now have my NULL MODEM CABLE and I will try and flash my box tonight.
When I re-flash the box will I need to re-scan all the satellites I have already scanned. If so, is there a way round it, i.e by copying the satellites.xml file from the box - if so, how can I access the file when connected via NULL MODEM CABLE.
Also, I was using a version of Gemini image and I am thinking of switching to Nabilosat BlackHole instead - will CCCam work on this image?
Does anyone have any thoughts on using BlackHole instead of Gemini?
Is that just a case of plugging the ethernet cable into box and into the laptop then using DCC?
Or is there something else I need to do?
Can I do that even though the box won't boot?
i.e Ping into 192.168.0.2 on my LAN (which is the static IP address)
I have just pinged into my box. I held the power button as it loaded.
The Web interface has come up and the titlebar says: Dreambox DM600PVR Web Interface... my box is supposed to be a DM800 is this just the web interface version on the box or does it sound like I've been fiddled?
