Results 1 to 13 of 13
    Top Poster Dowie's Avatar
    Apr 2008
    Default DK v1 image problem
    Hi all
    Got a strange one here! Ive an eagle and a dream clone and when i upload the DK image to both boxes the boxes go into a reboot cycle after flashing if I put the DW image they both bootup tried to reflash 3 times and re downloaded the image but the same thing happens!
    Any help would be great!!
    Dowie
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Quote Originally Posted by Dowie View Post
    Hi all
    Dowie
    Have you tried doing a flash erase before flashing it?,, ,and then proceed to flash
    boom!
    Apr 2008
    Hi Satman
    Actually no i havent it just seem strange that its only this image thats affected DW and others are fine!
    Does Flash erase not kill the bootloader?
    Dowie
    Jun 2008
    Never Never Land
    Hi Satman
    Dowie
    no,, use dreamup and do a flash-erase first( conect up by serial and connect and click flash erase),,,,,,,,
    then try and reflash it,,,
    and no, your flash erase aint nothing to do with bootloader that aint part of the flash memory
    boom!
    Apr 2008
    Talking
    Cool
    Cheers Satman ill give it a try tonight!!
    Apr 2008
    Oh no guess what!!
    3:18:36 PM box type: DM500
    3:18:49 PM Ping result: OK, box is alive and speaking to us ;-)
    3:18:55 PM erasing complete flash (without bmon stage of course)...
    3:19:05 PM ERROR, flash-erase failed, box will be unusable now!!
    What do i do now
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    strange .. can u connect to ftp programe when its working on dw . if u can l send an image u can install in tmp folder and u can do a manual update
    Apr 2008
    I can flash the box now but it does nothing! Bricked??
    Dowie
    Mar 2008
    birmingham
    turn off the box and the plug send your firmware over and then turn on at the plug again ,
    Apr 2008
    Ive sorted it i think!!!
    I started from scratch again!!
    Erased flash as Satman advised
    Sent image over to box
    Seems to be working now
    Thanks for you help anyway matey!!
    Dowie
    Administrator
    Devilfish's Avatar
    Feb 2008
    If you have any problems with dreamup or images, do a flash erase TWICE (I know sounds silly but works) then download the firmware from the dream multimedia site and flash that. Once you have a working base, you can flash whatever image you want.
    There are also many different versions of dreamup, the dream multimedia site only shows the latest but a google search usually gets you a few older versions which can sometimes help.
    Jun 2008
    my guess is the image file is/was still rared/zipped when you tried to flash
    dreamup will flash the file but it will not work
  13. #13
    Mar 2008
    Quote Originally Posted by Devilfish View Post
    Is that goos advice with all the clone boxes about. Does the latest Dream image not screw up the boot loader of clones?
    I can't help thinking that new versions of DreamUp might be used to remove the boot loader from clone boxes as well soon. It might be a good idea to stick with a version from before the clone bombs started.
    500c, 600c, 7025+cc, 7000s with a 1m steerable dish
