Results 1 to 1 of 1
Hybrid View
    May 2012
    Rawalpindi, Pakistan
    Default Toyota Error Code: DTC P1300/14
    Description: Igniter Circuit Malfunction
    To repair the code please do the following:
    PART A
    1. Camshaft position sensor connector detached.
    2. Camshaft position sensor failure.
    3. Wiring.
    4. ECM.
    PART B
    1. Check spark plug
    2. Check for open and short in harness and connector in IGF signal circuit between
    ECM and igniter
    3. Disconnect igniter connector and check voltage between terminal IGF of ECM
    connector and body ground.
    4. Check for open and short in harness and connector in IGT1 ? 3 signal circuit
    between ECM and igniter
    5. Check voltage between terminals IGT1 ? 3 of ECM connector and body ground.
    6. Disconnect igniter connector and check voltage between terminals IGT1 ? 3 of
    8. Check for open and short in harness and connector between ignition switch and
    ignition coil, ignition coil and igniter
    9. Check ignition coil
    10. Check and replace ECM
  2. The Following User Says Thank You to shadab For This Useful Post:
    maygirl (12th September, 2014)
