Diagnose the car and find out fault code[s]?
C8-(eco - power remap) dpf off.rarCan someone have a look at this remap to see if dpf is removed as still getting anti pollution fault on dash ?
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
Fault codes P1147 & P1429
Those faults relate to sensor faults, if DPF was removed properly it should not be there.
DPF is off correctly, but i think you must simulate a "good" diff. pr. about 10-15 mbar if your diff. sensor is faulty.
This EcuSafe solution always work for me, but i've never had a problem with faulty sensor...
Regards!
Kev10001 (13th September, 2014)
Thanks for replys , Do I have to disable anything and do I leave all sensors connected?
Regards...
Read again what i've wrote...
"but i think you must simulate a "good" diff. pr. about 10-15 mbar if your diff. sensor is faulty"
That mean all sensors stay connected and in good condition...
EDIT: i can't find what mean P1147, maybe is P1447?
