SKP900 yes and no
Page 1 of 52 1234561151 ... LastLast
Results 1 to 15 of 770
    5
    Default SKP900 yes and no
    can people add yes and no to this key tool for different cars
    Just added key to 2008 MCC Smart Passion with no problems
  2. The Following User Says Thank You to jensen1 For This Useful Post:
    Cliff hope (2nd August, 2016)
  3. #2
    gwee's Avatar
    Dec 2012
    unknown
    1,800
    skp900.........
  4. The Following 5 Users Say Thank You to gwee For This Useful Post:
    Cliff hope (2nd August, 2016),CLK1201 (13th September, 2014),dd1 (14th April, 2018),keyantic (1st May, 2015),narkeleptk (28th May, 2017)
  5. #3
    5
    I take it your not impressed with this tool!!!
  6. #4
    gwee's Avatar
    Dec 2012
    unknown
    1,800
    skp900.................
    Nov 2010
    6
  8. The Following User Says Thank You to viw9419 For This Useful Post:
    Phase 4 autokey (21st September, 2014)
  9. #6
    karachi,pakistan
    77
    i not impressed with this tool batter x100
  10. #7
    5
    Maybe it's best if we keep the comments to what it will do and what it will not do and then it will be obvious if it's of any value
  11. #8
    gwee's Avatar
    Dec 2012
    unknown
    1,800
    Quote Originally Posted by jensen1 View Post
    in that case you should change the subject of this thread
  12. #9
    5
    Your suggestion for a subject would be welcome
  13. #10
    gwee's Avatar
    Dec 2012
    unknown
    1,800
    ......................"buy skp900 and get a free iPhona 6"
  14. The Following 2 Users Say Thank You to gwee For This Useful Post:
    NiZaTroniC (5th July, 2015),twalters (25th November, 2017)
  15. #11
    west mids, uk
    465
    SKP900: AS TESTED BY ME: (on version 26) - now updated to ver 27
    WORKING
    FORD FIESTA 2009 - WORKING NO CODES NEEDED
    FORD FOCUS 2007 - NO CODES NEEDED
    FORD CONNECT VAN 2007 WORKING- NO CODES NEEDED
    RENAULT MEGANE 2004 READ PIN AND PROGRAM
    NISSAN ALMERA 2003 - WORKED AND CALCULATED CORRECT PIN FROM BCM LABEL
    NISSAN NAVARA 2010 - READ CORRECT BCM VIA OBD, CALCULATED CORRECT PINCODE AND PROGRAMMED (AVDI FAILED!!)
    JAGUAR X TYPE 2008 - WORKED
    NOT WORKING
    RENAULT SCENIC 2008 READS WRONG PINCODE
    FORD FOCUS 2001 NOT WORKING
    FORD FOCUS 2008 NOT WORKING
    FORD CONNECT VAN 2003 NOT WORKING
    FORD MONDEO 2003 TDCI NOT WORKING
    FORD KA 2003 NOT WORKING
    FORD FIESTA 2006 NOT WORKING
    FOR FIESTA 2005 NOT WORKING
    FORD MONDEO 2002 NOT WORKING
    I WILL UPDATE THIS LIST AS I GO ALONG
    Can anyone confirm what landrover/rangerovers it works on, what year and if spare or lost keys, thanks.
    I hope the working list starts to catch up on the not working list
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  16. The Following 15 Users Say Thank You to ninja123 For This Useful Post:
    + Show/Hide list of the thanked
    antonypaul (15th April, 2016),jensen1 (14th September, 2014),keymaker.gr (8th October, 2014),mburu (29th October, 2016),nyandacca (9th June, 2015),paul_12345 (4th October, 2014),Recoder (23rd July, 2015),sagutani (6th February, 2017),Siham (24th February, 2015),super jumbe (14th September, 2014),thug252 (16th April, 2018),urcarpc (8th February, 2016),viw9419 (4th October, 2014),wheepy (20th April, 2017),workdamnyou (14th September, 2014)
  17. #12
    5
    Version < 2.6 will not do early euro fords by all accounts
    Version > 2.6 will - we hopefully shall find out !!
  18. The Following User Says Thank You to jensen1 For This Useful Post:
    purdy (4th April, 2016)
  19. #13
    68
    new version update
    SuperOBD SKP-900 Key Programmer V2.7 Released! (Sept. 12th)
    Previous
    1. FORD Key Program with HEC ID-4C(1999-2004)
    2. LINCOLN Key Program with HEC ID-4C(1999-2004)
    3. FORD Key Program with PCM ID-4D(2002-2004)
    4. LINCOLN Key Program with PCM ID-4D(2002-2004)
    5. Ford Mustang Remote Key Program(2011-2014)
    6. New FORD Fix BUG
    7. MAZDA 6 Smart Key Fix BUG
    Update atach
  20. The Following 3 Users Say Thank You to elektro128 For This Useful Post:
    ADUIR (16th July, 2015),Automat (19th September, 2014),Phase 4 autokey (14th September, 2014)
  21. #14
    Member Phase 4 autokey's Avatar
    Apr 2014
    www.sopl.us
    154
    Is this specific to your tool only?
  22. #15
    Question
    so as ninja did, i think everybody here should do the same , post here , your skp is working or not , where it worked , car ( brand, year, model) and where it failed , (brand, year, model, ecu number ....)
