Results 1 to 4 of 4
Thread: Sound problem
    Feb 2014
    Liverpool
    Default Sound problem
    Don't know if this has been covered in another thread ..
    on some channels the sound will cut out for like a second then come back on
    has anyone got a solution to fix this ..
    i have a f5 s
    DK Veteran bigade1's Avatar
    Oct 2013
    If I remember correctly, this is a known bug. I think the cure is to make sure the " Timeshift " setting is switched to " Off " in the " PVR Settings " which can be found in the Menu Settings.
  3. The Following User Says Thank You to bigade1 For This Useful Post:
    pgreenie1 (14th September, 2014)
    Feb 2014
    Liverpool
    I'll give it a go thanks ..
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by pgreenie1 View Post
    i have a f5 s
    You need the latest software called Libertview this will solve your sound issue.
