Results 1 to 10 of 10
    Dunker's Avatar
    Yorkshire
    Default 2007 Vauxhall Vivaro M9R
    Has anyone got a wiring diagram for the ECU on a M9R engined Vivaro. This ones going to be a pain, got to strip the full loom out of it by the looks. Before it came to me its had an brand new engine (Sewells screwed summat up badly when first looking at it), injectors, ECU also all brand fire new etc. They have spent a fortune on it. No fault codes. Cuts out when booted - just like overboost - but I've had the scope on it and none of the sensor signals look out of the ordinary. Could be the pump I suppose but its had a 2nd hand one on as well. The usual scuttle water issues are there as well.
    Thanks in advance.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  2. The Following User Says Thank You to Dunker For This Useful Post:
    st3rg (16th September, 2020)
  3. #2
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Here you go VIVARO.rar
  4. The Following 4 Users Say Thank You to Faraday For This Useful Post:
    Dunker (20th September, 2014), jmac200t (3rd October, 2018), st3rg (16th September, 2020), Subix (12th December, 2020)
  5. #3
    Dunker's Avatar
    Yorkshire
    Thanks for that. Was there something to the left of the diagram?
  6. The Following User Says Thank You to Dunker For This Useful Post:
  7. #4
    Faraday's Avatar
    May 2012
    Here it is VIVARO2.rar I missed sorry.VIVARO_block diagram.rar
  8. The Following 5 Users Say Thank You to Faraday For This Useful Post:
    Donabe (14th February, 2018), Dunker (21st September, 2014), ivivaro (4th October, 2023), jmac200t (3rd October, 2018), st3rg (16th September, 2020)
  9. #5
    Dunker's Avatar
    Yorkshire
    Outstanding.
    Thanks.]
  10. #6
    Aug 2018
    Hi, im after the same files too but links wont work. Are these file uploaded anywhere else?
  11. #7
    Feb 2019
    Hi, I am also trying to download, but not working.
  12. #8
    Thank you for sharing !
  13. #9
    Apr 2023
    Default help please
    after same info, wiring diag for 2007 M9R vivaro, showing ECU (trying to trace injector fault, infamous P2149 code) does this link still work ? many thanks in advance
  14. #10
    Apr 2023
    managed to open second links ok, but doesnt show injector wiring, sadly.
