Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    Nov 2010
    Default 2012 ducati panigale 1199s
    Hello guys a have this ducati with no keys and i see that tmpro2 with module 182 can read it motorola 9s12p128 the problem is i dont have any motorola component in the antenna i found a 8 leg eeprom on it , maybe somebody have any idea how can i make a key for it.
    Thanks in advance
    Maxi
    gepakg's Avatar
    Serbia
    you want to play with ducati,for sure it is zadi immo type2 and motorola 9s12p128 inside,leave it,it is my friend opinion because you dont recognize eeprom or mcu...
    regrads Gepa
    Quote Originally Posted by gaxi View Post
    Thanks in advance
    Maxi
    Nov 2010
    Yes Bogi from tmpro2 send me instructions how to make it with module 182 but the problem is that module is crazy expensive if I need to buy this module I will be loosing a lot of money on the job and I really don't know when I will have another 1199s with no key
    gepakg's Avatar
    Serbia
    then if you not make money with this job,leave it...another friend opinion your customer know how much it cost in ducati service and how long it try???
    regards Gepa
  5. The Following User Says Thank You to gepakg For This Useful Post:
    gwee (23rd September, 2014)
    DK Veteran 54321's Avatar
    There will be nobody else in your area that can make a key for that bike so charge the customer the same price as the module and then you've got the module for free for future use
    Nov 2010
    Good point like always
    gepakg's Avatar
    Serbia
    i can make present for you for free you read 9s12p128 it is simple job on 4 wires and i will give you code from dump to start bike with any key,called `emergency start`,so will run as air,but only what i ask for you simple job,read mcu,4 wires...
    regards Gepa
  9. The Following User Says Thank You to gepakg For This Useful Post:
    motorbike59 (20th September, 2023)
  10. #8
    Nov 2010
    Ok Gena that mcum 9S12P128 it's not on the antenna so will be in the cluster?
  11. #9
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by gepakg View Post
    regards Gepa
    you are here, no wonder these days not getting many Ducati
  12. The Following User Says Thank You to gwee For This Useful Post:
    gepakg (23rd September, 2014)
  13. #10
    gepakg's Avatar
    Serbia
    no,exactly in antenna ZADI is mcu,4 wires,Vdd,Gnd,bdm,reset...dont be lazy,its pcb 5cm x 5cm
    regards Gepa
  14. The Following User Says Thank You to gepakg For This Useful Post:
  15. #11
    Nov 2010
    I hope one day to have your degree of noleg but I am just beginning to get into bikes. I'm not afraid to dig into it but with a little bit more help on diagrams and equipment. I really appreciate the help that you provide me
  16. #12
    gwee's Avatar
    Dec 2012
    unknown
    you are lucky to get help from gepa, he is the guru for bikes in europe
  17. The Following User Says Thank You to gwee For This Useful Post:
  18. #13
    gepakg's Avatar
    Serbia
    i am glad to hear that from you,it means more to me
    regards Gepa
    Quote Originally Posted by gwee View Post
  19. The Following User Says Thank You to gepakg For This Useful Post:
  20. #14
    get a room
  21. #15
    gwee's Avatar
    Dec 2012
    unknown
    you jealous?
  22. The Following User Says Thank You to gwee For This Useful Post:
