Results 1 to 5 of 5
    Fec001's Avatar
    Default Fiat Ducato 2.3 MJET 120 DPF off
    Hi!
    Please switch off DPF in this dump. VOLTA/EuSafe not ok.........
    try this file
    pass pm
  3. The Following User Says Thank You to pinotec For This Useful Post:
    Fec001 (25th September, 2014)
    Fec001's Avatar
    Seems ok, note the actual km in dash and distance travelled since last regen will see if regeneration procedure start.
    Later will check difference beetwen files.
    check car equipment , clogging dpf , sensor pressure ,and sonde if possible with diagnosis
    Fec001's Avatar
    Checked all with MES.
    Diff press. sensor 0 mBar
    Particle filter status: not cogged
    Particulate filter clogging: 1.39%
  7. The Following User Says Thank You to Fec001 For This Useful Post:
    pinotec (29th September, 2014)
