Results 1 to 14 of 14
    Default few channels missing on the box
    hi. i have a starview the box but a few of the channels are now missing like star plus, zee tv, bbc1+2 and many others. i have tried resetting and scanning near 50 times but none of these channels come. i am in oldham and with virgin media (EX C&W). has anything changed that i am not aware of? any help would be very appreciated. thanks
    Jun 2009
    Hi, my box is the same. Apparently they have not changed all the channels to nagra 2 and bbc1/2 ch4 utv and a few others are still on nagra 1. I am told they will change these over to nagra 2 soon so if you do regular rescans you may find that you will get these.
    Hope this helps.
    Cheers.
    what do you mean by nagra?
    Jun 2009
    That seems to be what the encrypition is called. Do you have the box super usb or the box. There is a download available for the box super usb which may fix your problem but you may want to read other forums before you do any reflashing in case it makes things worse.
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    nagra is short for nagravision. the term is used when referring to the level of nagravision encryption used by your catv provider... In the UK the transmission is via nagra1 in ireland nagra2 is in use as stated above,,,
    Quote Originally Posted by eirejk View Post
    eirejk i have the box. will virgin media be changing everything to nagra 2? if they do so will i need to install any software or just enter a new code? will my box even work?
    stockport
    no, mate, nothing has changed in uk. ignore eirejk.what box have you got and have you got correct f/ware for it?
    try menu, 1570, default then back to slyspts. wait for update. also, missing channels can sometimes be found after 999. loads of others there. try scan with t/pest as well. i get stuff with t/pest and xc/w..in stockport.
    do you do factory reset as well? hope this helps. ynwa
    maca's Avatar
    Feb 2009
    liverpool
    Quote Originally Posted by boomer39 View Post
    well said m8.. maca..
    i have got 'the box' (thats what it says on the front anyway). this is what info it gives me API ver: 4.51e_E Bootver: 7.0 9.July 2007. i have tried all this but am still getting the normals ones i get with exc&w. will i have to install any new software or anything or will the problem sort it self out in time if i just keep on rescanning it? if i have to install any new software how? i am in oldham using virgin media if it helps. thanks mate
    stockport
    Quote Originally Posted by oli949 View Post
    yes, mate, you need latest software. pretty sure you have an sv1 or sv2. different software for all 4 boxes. you need a null modem cable to download from pc to your box. also you need to get software from the above red stickies. it can be a bit daunting at first,but well worth the effort. i'm not used to sv1/2 but the guys here will help....
    hi mate. thanks for your help. one last question though. when should my box (sv2) be turned off and when during the update should it be turned on?
    thank you all for your help. i've fixed my box: hooray!
  13. #13
    i had star view 4 with same promlem new software all ok now not sure about older starview the software is in downlods aera
  14. #14
    DK Veteran khenryashley's Avatar
    Gods country
    Quote Originally Posted by banko View Post
    What older starview do you have?
