Results 1 to 4 of 4
Thread: Vectra C
    Default Vectra C
    Tried to programme key with Tech2Win
    Inserted un-programmed key, switched the ignition on when prompted, then it says please wait, after few seconds it says switch the ignition on but the ignition is already on.
    1 fault code B3601: Key Capture Relay. Any idea what or where it is?
    Any help will be greatly appreciated.
    P&D's Avatar
    Have a look here might point you in the right direction
    Hidden cause
  3. The Following 3 Users Say Thank You to P&D For This Useful Post:
    gurmk (27th September, 2014), Recoder (28th September, 2014), willywonker2010 (29th September, 2014)
    amrif's Avatar
    EU
    link is dead, can someone renew? I have the same problem after CIM replacement.
    If I helped you please remember to give thanks and rep. A little thanks goes a long way
    P&D's Avatar
    Quote Originally Posted by amrif View Post
    Not sure if this will help you but might do
    http://www.digital-kaos.co.uk/forums...-C-CIM-problem
