Results 1 to 11 of 11
Thread: Help please
    Dec 2013
    Default Help please
    Could anyone tell me if I closed EGR right?
    thanks in advance
    Sep 2014
    Yes it is
    Dec 2013
    But why after 3000 rpm the car wrote P0400? If I am closing right shouldn't write it
    Sep 2014
    Did you fisically shutted down the egr valve, with a blank piece of metalsheet?
    Dec 2013
    No, i only disconnect a vacuum and I close a vacuum pipe.
    Why should I put a metal sheet when I close it with EGR map
    Sep 2014
    You should mate...
    Oct 2012
    before mod file you haved sommes probblems with egr?
    do not disconect connector
    Sep 2014
    The egr valve, if its not blanked/shutted down with this sheet, always lets some exhaust gases in the intake manifold and disturbs the combustion and as betrescudan sayed you should connect back the connector.
    Oct 2012
    4% it rest opened...if you make the metal sheet,make a drill 3-4 mm...regards
    Dec 2013
    Yes, I haved. Rubber inside in EGR was ripped and i can't found new EGR.
    For that i decide to close EGR.
    Dec 2013
    Thanks to all mates
