Results 1 to 15 of 20
Thread: fix MICRONAS
    Jan 2012
    Default fix MICRONAS
    Can someone please fix the flash from Micron.
    they're tacho 8P0 920 931 S.
    They are absolutely dead.
    EEPROM backup is 100% but Micronas dump damaged.
    Could you tell me please fix this?
    Thank you very much
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Your flash fixed. Pass PM:
    Jan 2012
    so,this is ok,tacho live but write in DTC 00003 - control module defekt
    its wrong checksum?
    It is because your firmware is patched
    Jan 2012
    Quote Originally Posted by exe123 View Post
    and lead me to fix it?
    Can fix it but as soon you connect again via OBD for mileage adjustment or immo data reading it will be patched again.
    Jan 2012
    Tried by abrites but still the error is there
    That error is normal because every obd tool is patching the firmware.
    100% clean solution via Jtag only!
    i never saw this error when patching it with smok tool on bench
    Error will not show on the bench. just in the car when the immo system is working
  11. The Following User Says Thank You to exe123 For This Useful Post:
    chriskross (28th September, 2014)
  12. #11
    yugo45's Avatar
    Not with SMOK X-Dash.Never had this code with X-Dash, Did swap many of Mirconas and made many keys for it.
  13. #12
    Jan 2012
    error fixed.
    dtc is clear after repair eeprom.
  14. #13
    After 10 minutes dtc will came back
  15. #14
    peko's Avatar
    hi friends
    i have here same dash (second hand ) to adapt in car ... but i not found where is stored VIN inside ? ( in micronas or 24c32 )
  16. #15
    yugo45's Avatar
    VIN Store in 24c32 , but it is encrypted ,
