MPPS read is ok, it jsut has some problems wirtting when it gets to the end. actually it writes ok but deletes the rest. so dont ever use mpps on edc16c39
as for kess i dunno i think it will write perfectly, but that file is a valid obd file!
Hi all,
I want to write a file to Vectra 1.9CDTI 120hp EDC16C9 ECU with Original Kess V2, but the Kess does not read, only write.
What file do I need to use?
I read the original ECU with MPPS V12, but I don't trust it to write to this ECU. I already have a BDM backup of this software, but I'd prefer
to do by OBD.
bondiblu (29th September, 2014)
dunno what it will write back but i doubt it will ask for a full bDM file.
i did do some testing on Fgtech and u can write a BDM file via OBD!
Yes you can write a BDM file via OBD at least on this ecu. For example the cars that have sport button, when you read it via OBD, it won't read that bank, only if you read it by BDM, and you can wright by OBD the bdm file.
I think kess will do the job, personally I never tried.
bondiblu (30th September, 2014)
kess work on writing good
use batterie charger
read -write OK obd can audi R4 ED B8,year 2008 engine 2 L,edc17,143 hp
