Results 1 to 3 of 3
    Sep 2014
    Default Copy increments of modded file into other ori file
    Does this makes sence? Or it must be done manually map by map?
    https://www.youtube.com/watch?v=XP2rd78EglE
    Oct 2012
    Quote Originally Posted by pittatore View Post
    theoretically you can do this...only that in ecm you can"t be sure about the names of maps...but,if you have a good map that work well,you must save all increments into a file,an use this on the same car...is like you coppy the increments on every map...i like a mappack or ols file on winols...i think is better using your creation to every car worked,depends of the km,years old,state of turbo,actualy consumption,etc...regards
  3. The Following User Says Thank You to betrescudan For This Useful Post:
    pittatore (1st October, 2014)
    Sep 2014
    Yes thats clear to me, these increments I save in .ind file and than use it for a another ecu of the same family.
    Curious to try it out
    Thanks for advice
