BMW... edc17 1037396562... safe for OBD programming
Results 1 to 11 of 11
    Nov 2013
    UK
    102
    Downloads
    20
    Uploads
    Default BMW... edc17 1037396562... safe for OBD programming
    can anyone tell?
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    242
    Downloads
    19
    Uploads
    which tool?
    247
    Downloads
    30
    Uploads
    yes, cmd can do in obd without problem.
    I made several, the last two months.
    Nov 2011
    273
    Downloads
    4
    Uploads
    is this only for specific clients from CMD, or is this available for all customers from CMD ?
    247
    Downloads
    30
    Uploads
    Sorry for delay.
    No, is for all user CMDtec.
    Software 1037396562, il old soft, have only TP v02.
    wiseman's Avatar
    243
    Downloads
    31
    Uploads
    Galletto tells you if the sw version is TPROT or not
    247
    Downloads
    30
    Uploads
    Yes, but im bmw do not rigth always.
    Nov 2013
    UK
    102
    Downloads
    20
    Uploads
    I tried with Galletto and it failed and made me write ori file. After I just did it boot mode and all ok
    xanubysx's Avatar
    Sep 2010
    EUROPE
    99
    Downloads
    185
    Uploads
    CMD and kessv2 think .. CMD 100% ok ,kessv2 no test this car support via obd drv now ok.. vag work normally and other too...
    Do not forget to THANKS !
    FGTech , Piasini , Lounch x431, Autel , BDM + Frame , Galletto 1260, , CMD BDM 100, X-Prog, UPA , PSA XS Evolution, KTS-520, VAG CAN PRO+K + SGO FULL Update all ECU, VCDS , AUTOCOM , MULTIDIAG , DIGIPROG III , CDC Marelli, Autel MAXIDAS 908, Supervag-FULL ,I/Terminal FULL, VCX NANO FORD\MAZDA
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V2
    K-TAG
    B-FLASH
    FILE SERVISE .. web under construction
    242
    Downloads
    19
    Uploads
    are these tools just make a virtual read or can they realy read flash over obd?
    247
    Downloads
    30
    Uploads
    Cmd, real read (partial read).
