Mercedes Sprinter 315 DPF off please s/w 1037400338
Results 1 to 8 of 8
    Birmingham
    70
    Default Mercedes Sprinter 315 DPF off please s/w 1037400338
    Hi there!
    Can anyone make this DPF off for me with a good solution?
    Its a Sprinter 315 CDi s/w 1037400338
    No ecusafe or volta please!
    11
    Quote Originally Posted by MarkPRP View Post
    Hi there!
    password p.m
    Birmingham
    70
    What did you make it with? Thanks I will test.. Anything I need to do?
    64
    Default dpf off
    Hi everyone
    off your DPF
    good luck
    11
    disable temperature sensors Dpf
    Birmingham
    70
    Quote Originally Posted by cavignac View Post
    Hi everyone
    off your DPF
    good luck
    Your file does not work gives dtc on all sensors unlplugged or plugged!
    Zebbon, Thanks but pass does not work so I cannot test!
    Germany
    27
    Dump DPF off ,disconnect connector from temperatur sensof and sensor diff.pressure. Pass PM
    best regards Eddy
  8. The Following User Says Thank You to 16eddi67 For This Useful Post:
    angelx431 (8th October, 2014)
    Nov 2010
    BY
    24
    Hi everyone off your DPF.
