Results 1 to 11 of 11
    Babos's Avatar
    Mar 2012
    Default Where i can find good working winols 2.24 64bit??
    Hi all.
    Who have good working version?
    I have version for 32bit all work good but in 64bit work but slowly!
    I try few versions from web and form forums but still not found good working soft!
    I can pay for working sowtware no problem
    DK Veteran 70max's Avatar
    May 2012
    Quote Originally Posted by Babos View Post
    Hi all.
    Hi my friend,
    Try this
    I've never tried it I do not have 64Bit
    but who gave it to me says it works.
    If it works well, press the thanks button
    Best Regards Max
    Babos's Avatar
    Mar 2012
    Thank you for all!
    For the moment i get few versions for test now i test v1 and work good.
    Thanks for chli1976
    Babos's Avatar
    Mar 2012
    UP
    report stilll have problem with sw some times work good but after start get pauses and thinking work slowly.
    Info about system windows 7 64bit I7 2.5Hz 16 ram 2gb nvidia
    UP
    deactivate antivir soft, then it is working faster
    Babos's Avatar
    Mar 2012
    i not have there any antivirus
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Buy original! Work very good! Gy
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    Babos's Avatar
    Mar 2012
    Yes sure but you must have LTD PADLA gygygy
    What do you mean LTD ? Just a company VAT...
    Babos's Avatar
    Mar 2012
    LTD is campany
    Nov 2012
    smartville in front of a OBDplug
    you tryed original on you computer ?
    you can buy online with vat
