Results 1 to 8 of 8
    BrunoPT's Avatar
    Oct 2011
    PT
    Default GOLF 5 1.4 FSI DON?T START AFTER PROGRAMING
    Hello everyone
    I need a your help.
    I have here a golf 5 1.4 fsi for 90hp
    I opened the unit and read by bdm (flash_read file)
    I made an off dtc calculated the checksum and recorded in the unit, it happens that the car will not start or light up the engine light on the dashboard. I try to put the file read and yet also not handle. What repair is that when writing for bdm initially wrote in + \ - 5m and now everything I write is written in 2m.
    Someone can give me a hint?
    ECU: BOSCH MED 9.5.10
    SOFTWARE: 1037376084
    HARDWARE: 0261S02004
    Attached file originally read (flash)
    eeprom
    File with DTC P1035 off
    Thank you
    Fantomisback's Avatar
    Aug 2012
    Quote Originally Posted by BrunoPT View Post
    Hello everyone
    I need a your help.
    eeprom
    Thank you
    Hi i think your checksum is not ok u can try this file
    BrunoPT's Avatar
    Oct 2011
    PT
    i will try, but for example, read by bdm initially to make the car work and does not do
    BrunoPT's Avatar
    Oct 2011
    PT
    Don?t work.
    Maybe you damaged the ECU while trying to open it.......
    MEd 9 get damaged v easy . as they are v v hard to open especially if u want to reach the other side where the bosch BDM pads are.
    PS: it has normal bdm pads on the first side!
    Fec001's Avatar
    or make chk with BDM100
    BrunoPT's Avatar
    Oct 2011
    PT
    Opening the unit was made ​​as I usually do and never had problems.
    I will soon have a new test file.
    I hope I have not corrupt is the micro
