Is possible adaptation with lexia this function ?
Yes possible to remove limiter.
upload file please I will check
Impossible; )
Sent from my SM-G900F using Tapatalk
Hello
someone managed to disable speed limit in the BSI. ECU Visteon dcu102 there is no speed limit on the map
Did you manage to successfully remove the limit in the BSI on the Relay you had Pawel11?
speed limit is in the BSI. Lexia in telecoding bsi shows 90km/h but you can not change disable
I agree..thanks
If you virgin bsi and recode?
I tried with Lexia and never were abble to do it.
And never knew someone that was to recode it.
But we learn something every day..
Is it possible to virginise a used BSI ?
If answer is no we will need to read & edit BSI memories directly.. is it NEC or Motorola MCU?
Of course it's possible, depends of bsi what there are inside nec, or hc mcu, mostly they have just plain eeprom (95160 or something like that) and just needs to put FF
Don't know what kind of bsi boxer has... Only seen nec in xsaras/berlingos, and hc mcu's in van plexed cars, can cars seem to have plain eeproms.
Old trade I play but not solved it
you can recode this BSI with cheep tool >>>> FICOM
but us not work alone to recode BSI
so it think also to make in DCU102 Visteon , some guys here know how ?
citroen dealer write to his support they told customer have to changed BSI AND ECU TO A NEW ONE AND RECODE
