Results 1 to 10 of 10
    Oct 2014
    Question Rescued Wii from BSOD with a new error message greeting me
    Hello everyone, let me first start out by saying I'm no stranger to Softmodding Wii's, I have done over 10 of them, some of them have been easy while others have required a bit more work to fix up. I also wanted to say that I really like the community here and there are some very talented individuals who post. Which is why I'm about to tell you my current problem after rescuing a Wii from a Black Screen Of Death.
    I followed the direction of the number of people who were able to rescue Wii's from the BSOD from installing a Bluetooth Module. I stripped the Wii down to the core, where only the bottom of the plastic case remains, everything else is exposed. I even disconnected the DVD Rom Drive because it wasn't functioning. After installing the new Bluetooth Module I was able to load up into the System Menu and install The Homebrew Channel and all the cIOSes that would make my games run off of a external USB Drive successfully but this is where my trouble started again....
    I am getting an error message after a delayed startup of all games I try to play that says: "An error has occured press the eject button remove the game disc and turn off the power to the console." I have had a few other consoles with bad DVD Roms with homebrew installed successfully on them but none of them actually had the DVD Rom REMOVED....so here is my question, by disconnecting the drive did I bring this error message out at me and how would I go about correcting it?
    Let it be noted I can still access everything okay, including The Homebrew Channel and the Wii System Menu I just can't play any Games.
    Oct 2014
    Here is my syscheck.csv result:
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Priiloader installed
    Could not detect the drive date!
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 149659917
    Boot2 v4
    Found 62 titles.
    Found 44 IOS on this console. 3 of them are stub.
    IOS3 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS17 (rev 1032): No Patches
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6174): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6687): Trucha Bug
    IOS80 (rev 6944, Info: rev 6944): Trucha Bug
    IOS202[60] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535, Info: Hermes-v55.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[37] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS248[58] (rev 65535, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 65535, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21010, Info: d2x-v10beta52): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/10/08.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    You have a mixture of d2x wads
    Its strange you don't have IOS20, IOS30, IOS50, IOS51. You need to install IOS40 download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads with Multi Mod Manager (MMM).
    You really need a compatible mains powered hard drive to add the games onto.
    Keith
    2010 Golf GTD (170)
    Oct 2014
    I did everything you asked, and it still gives me that error message. What happens is everything loads up in WiiFlow, I click a game, the load bar loads up a 4th of the way and hangs....then nearly 30 seconds later the bar loads up the rest of the way and it hangs on a black screen for awhile then in big white letters is says: "An error has occurred, press the eject button, remove the disc, and turn off the power to the console." It also says something about looking in the Wiimanual for an answer.....but we all know that the wiimanual can't help us here, . Keep in mind i installed homebrew without the DVD Rom being hooked up, it won't work at all, but I figured I didn't need it because I have a USB drive with all the games on it. That USB drive was hooked up to other wiis that have homebrew installed and it worked fine with them. I have never modded a wii without the drive being hooked up though, do you think that caused it?
    Oct 2014
    here is an updated syscheck:
    Region: NTSC-U
    Hollywood v0x21
    Boot2 v4
    Found 73 titles.
    Found 49 IOS on this console. 1 of them are stub.
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10
    Report generated on 2014/10/10.
    Aug 2010
    England
    Well there is nothing wrong with that new sysCheck. You don't really need the DVD drive if the USB drive works.
    Does it show any error number?
    Keith
    2010 Golf GTD (170)
    Oct 2014
    No error number, just SOMETIMES it says "disc loading...." which fades in and out before showing the error message "An error has occurred, press the eject button, remove the disc, and turn off the power to the console." I feel like someone somewhere knows the answer to this problem because I've read others experience it after playing Call Of Duty, I did a quick search on google, but no one responded with a direct answer to that problem so far, the best answer was "Send it into nintendo for a repair" but they replace your unit with a new one, I believe its one of those problems that requires a reflash of its operating system to fix.
    Is it possible that reinstalling the homebrew channel might fix the problem or install it to a different IOS? I also looked at my last syscheck again and noticed that IOS51 was missing, do you have one that I can install?
    Aug 2010
    England
    My IOS51 (rev 4864): is Stub, Mothballed, used by shopping channel 3.4 only and my Wii works perfectly.
    My sysCheck sysCheck #MKWDueNa
    Keith
    2010 Golf GTD (170)
    Oct 2014
    My IOS51 is missing. How would I go about recovering it if it is the cause of the disc loading error?
    Aug 2010
    England
    If you want to make your own wads use NUS Downloader - WiiBrew (update the database first) that will make IOS51-64-4864.wad which you install with Multi Mod Manager (MMM).
    Keith
    2010 Golf GTD (170)
