Page 9 of 15 FirstFirst ... 4567891011121314 ... LastLast
Results 121 to 135 of 213
  1. #121
    May 2009
    Digital Kaos
    I have updated the CWAITE Sky numbered channel list, with the following changes, there is also a list which excludes the Adult Channels
    18/05/2016
    Absolute CR renamed Classic Rock and Moved Transponders
    Absolute80s renamed Absolute 80s and Moved Transponders
    Abs Rad 90s renamed Absolute 90s and Moved Transponders
    Absolute moved transponders
    BON TV Moved Transponders
    Daystar Removed
    EMAN CHANNEL added to 857
  2. The Following 10 Users Say Thank You to cwaite For This Useful Post:
    ascouser (21st May, 2016), ColinBos (21st May, 2016), grog68 (25th May, 2016), joe516 (19th May, 2016), mjon (19th May, 2016), okverd (21st May, 2016), pappafoz (20th May, 2016), RaySav (19th May, 2016), stualdo (19th May, 2016), zappman (18th July, 2016)
  3. #122
    May 2009
    Digital Kaos
    Smash Hits (362) renamed to Box Hits
    Heat (364) renamed to Box Upfront
    Box Upfront (364) moved to 359
    The Box (359) moved to 360
    Box Hits (362) moved to 361
    4Music (360) moved to 362
    Kiss (361) moved to 363
    Magic (363) moved to 364
    BT Sport SD Changed Transponders
    BT/ESPN SD Changed Transponders
    I HAVE REMOVED THE LATEST CHANNEL LISTS AS SOME PEOPLE ARE FACING ISSUES WITH THE MOST UP TO DATE LISTS
  4. The Following 4 Users Say Thank You to cwaite For This Useful Post:
    ColinBos (26th May, 2016), joe516 (25th May, 2016), mjon (25th May, 2016), umnama (27th May, 2016)
  5. #123
    May 2009
    Digital Kaos
    I have RE-UPLOADED the CWAITE Sky numbered channel list that was issued on 25th May, due to a very small number of people saying that they had problems with the original list, I have been unable to reproduce these problems myself.
    I have re-made the list to reflect the changes made on 25th May 2016 and the re-made list can be downloaded below.
  6. The Following User Says Thank You to cwaite For This Useful Post:
    joe516 (30th May, 2016)
  7. #124
    May 2009
    Digital Kaos
    I have re made the CWAITE Sky Numbered Channel Lists dated 25/05/2016 due to some people having issues with their box being stuck in a loop, I have remade the list from the last known working list which was dated 18/05/2016. If anyone out there is willing to test the remade list please give it a whirl, and let us know if you have any problems.
    25/05/2016
    01/06/2016
    Church Channel Renamed Hillsong
    True Crime Moved Transponders
    Playboy TV Hot Renamed xxxPublicPikUp
    *** ALL BT SPORT HD CHANNELS ARE OFF, IT LOOKS LIKE THEY MAY HAVE SWITCHED THE ENCRYPTION TO HARDWARE PAIRING WHICH MEANS NO BOX OTHER THAN AN OFFICIAL $KY HD BOX WITH A VALID SUBSCRIPTION WILL BE ABLE TO UNSCRAMBLE ANY BT SPORT HD CHANNELS, BT SPORT SD CHANNELS ARE STILL WORKING ***
  8. The Following 6 Users Say Thank You to cwaite For This Useful Post:
    00360362878 (1st June, 2016), ColinBos (6th June, 2016), CrAcKeDuPII (2nd June, 2016), goldberg (2nd June, 2016), joe516 (2nd June, 2016), mjon (3rd June, 2016)
  9. #125
    May 2009
    Digital Kaos
    03/06/2016
    Hillsong moved transponders
    Jewelry Maker Changed Transponders
    Made In Cardiff Changed Transponders
    BT Sport HD Channels Swapped with SD and BT HD Channels are now Skipped with using the up/down channel buttons
  10. The Following 12 Users Say Thank You to cwaite For This Useful Post:
    00360362878 (5th June, 2016), B00B00 (4th June, 2016), BawJaws (5th June, 2016), beddy007 (4th June, 2016), biggeo (4th June, 2016), chris1968 (5th June, 2016), ColinBos (6th June, 2016), metalhead (6th June, 2016), mjon (4th June, 2016), okverd (4th June, 2016), vaIedark (6th June, 2016), wrecker1 (6th June, 2016)
  11. #126
    May 2009
    Digital Kaos
    05/06/2016
    Extra BBC Red Button Channels Added to 982 to 986
    AMC From BT Swapped and HD channel skipped (as no longer working on non official Sly Boxes)
    S4C HD added to 280
    Sky Sports News HQ (ALT) on 1261 changed Transponders
    Film 4 Test added to 1201 (no picture at present)
    We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote then scroll up or down to the last Favourite Section (labelled Fav Group 32 or ALL CHANNELS).
    To Get back to the Sly channel numbers Press SAT LIST on your Satellite Remote then press EXIT, your channels will be back to the usual Sly numbers (i.e. BBC ONE on 101, BBC TWO on 102, ITV on 103 etc)
  12. The Following 2 Users Say Thank You to cwaite For This Useful Post:
    joe516 (7th June, 2016), satsmo (6th June, 2016)
  13. #127
    May 2009
    Digital Kaos
    06/06/2016
    Added Alternative SD Versions of BT Sport 1, 2, Europe & ESPN to channels 1264, 1265, 1266, 1267 (for anyone having problems getting the main BT Sport SD Channels)
  14. The Following 6 Users Say Thank You to cwaite For This Useful Post:
    amos4k (7th June, 2016), badboy1965 (7th June, 2016), fatbob46 (11th June, 2016), floormanager (11th June, 2016), joe516 (7th June, 2016), okverd (9th June, 2016)
  15. #128
    May 2009
    Digital Kaos
    16/06/2016
    Home&Leisure added to 237
    3e Changed Transponders
  16. The Following 5 Users Say Thank You to cwaite For This Useful Post:
    Fiestyfeline47 (17th June, 2016), joe516 (17th June, 2016), mart16 (19th June, 2016), mjon (17th June, 2016), okverd (17th June, 2016)
  17. #129
    May 2009
    Digital Kaos
    24/06/2016
    GINX eSports TV added to 470
    BBC Red Button HD Moved from 986 to 980 all other RB channels moved up one channel
    Sky Box Office 18 Moved Transponder
  18. The Following 3 Users Say Thank You to cwaite For This Useful Post:
    davem49 (27th June, 2016), joe516 (24th June, 2016), okverd (25th June, 2016)
  19. #130
    May 2009
    Digital Kaos
    28/06/2016
    CNN SD Moved to 579
    CNN HD added to 506
    FEC for 11.426 V changed to 5/6
  20. The Following 5 Users Say Thank You to cwaite For This Useful Post:
    cakey2015 (29th June, 2016), joe516 (29th June, 2016), mart16 (29th June, 2016), mjon (29th June, 2016), tizrite (1st July, 2016)
  21. #131
    May 2009
    Digital Kaos
    29/06/2016
    Bloomberg Moved Transponder
  22. The Following 3 Users Say Thank You to cwaite For This Useful Post:
    00360362878 (30th June, 2016), mjon (30th June, 2016), tizrite (1st July, 2016)
  23. #132
    May 2009
    Digital Kaos
    30/06/2016
    Lifetime +1 Moved Transponder
    Crime+Inv +1 Moved Transponder
  24. The Following 5 Users Say Thank You to cwaite For This Useful Post:
    joe516 (1st July, 2016), mart16 (5th July, 2016), mjon (30th June, 2016), tizrite (1st July, 2016), umnama (6th July, 2016)
  25. #133
    May 2009
    Digital Kaos
    05/07/2016
    Setanta Sports Ireland renamed eir Sport 1
    Setanta Sports 1 renamed eir Sport 2
    Setanta 1 HD renamed eir Sport 2 HD
    Box Upfront moved transponders
    At The Races moved transponders
    Motors TV removed
    Babestation renamed Babenation and moved transponders
    Magic Moved Transponders
    Film 4 Ireland added to 1130
    Star Jalsha renamed Star Utsav
    Some HD changes
    (these are not avaliable on any box other than an Official $ky HD box with a valid subscription)
    Nick Jr. HD added to 637
    12012V changed FEC from 3/4 to 8/9
    Star Plus HD Moved Transponders
    Discovery HD Moved Transponders
    Fox HD Moved Transponders
  26. The Following 7 Users Say Thank You to cwaite For This Useful Post:
    00360362878 (8th July, 2016), alfadel (8th July, 2016), ali252 (10th July, 2016), joe516 (6th July, 2016), mjon (6th July, 2016), okverd (9th July, 2016), Teltech (12th July, 2016)
  27. #134
    May 2009
    Digital Kaos
    11/07/2016
    Sky Sports 1 moved to 401
    Sky Sports 2 moved to 402
    Sky Sports 3 moved to 403
    Sky Sports 4 moved to 404
    Sky Sports 5 moved to 405
    Sky Sports News HQ moved to 406
    Babes From TV changed Transponder
    Made In Bristol changed Transponder
    HD Changes only applicable to Official $ky HD boxes with an official subscription
    Sky Sports 1 HD Moved to 408
    Sky Sports 2 HD Moved to 409
    Sky Sports News HD moved to 440
    Sky SpN HQ HD Changed Transponder
    Sky Sports 1 Changed Transponder
  28. The Following 2 Users Say Thank You to cwaite For This Useful Post:
    joe516 (12th July, 2016), okverd (12th July, 2016)
  29. #135
    May 2009
    Digital Kaos
    Don't forget, We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote then scroll up or down to the last Favourite Section (labelled Fav Group 32 or ALL CHANNELS).
    13/07/2016
    AMC from BT Moved Transponders
    BT Sport Mosiac i2 added to 1295
    BT Sport Mosiac i1 moved Transponders
    Nick Jr HD Moved Transponders (only available on official $ky HD boxes with an official subscription)
  30. The Following 7 Users Say Thank You to cwaite For This Useful Post:
    badboy1965 (16th July, 2016), granty87 (17th July, 2016), joe516 (14th July, 2016), mart16 (15th July, 2016), okverd (15th July, 2016), RaySav (20th July, 2016), rexbomb (16th July, 2016)
