Results 1 to 7 of 7
    Member AutoElectronicaFS's Avatar
    Apr 2014
    Rafaela, Santa Fe, Argentina
    Default Need P2015 OFF VW TIGUAN 2.0TDI EDC17CP14
    Hi, can someone help me with this P2015 DTC OFF?
    P2015 - Intake Manifold Flap Position Sensor (Bank 1) Implausible Signal
    I Read file with Galletto with OBD2, but Galletto recomend me to write file with BOOT MODE because EDC17 Tricore have ChipTuning protection, is this right? or i can write file with OBD2 too?
    Thanks in advance for help!.
    Here is the original file.
    Tiguan_2.0TDI_EDC17CP14_IYR276.rar
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Boot mode is more safe to you...
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  3. The Following User Says Thank You to boomeer For This Useful Post:
    AutoElectronicaFS (10th October, 2014)
    Hi! pass pm
  5. The Following User Says Thank You to pelot For This Useful Post:
  6. #4
    Apr 2014
    Quote Originally Posted by pelot View Post
    Hi! pass pm
    Thanks my friend, it works fine!.......DTC OFF for ever!
    Dec 2012
    uk
    hello. someone will help me remove P2015. I tried to do but don't work
    03L907309_passat cc_cbabEDC17_cp14.rar
  8. #6
    waldi1979's Avatar
    Dec 2010
    Try this file and report.
    Pass PM.
  9. #7
    May 2017
    Default DTS OFF PASSAT CC 2009
    PLISE HELP PASAT CC 2009 TDI DTS OFF P2015
