my story is the same
I"m wayting for wideband device, and knock checker to take car in extreme tunning
BR
I have attached my ori and mod file but car seems to be slower. Any idea why?
Thank you in advance
330ms43ori_tuned.zip
BR
My work is my life ART TECH GARAGE
i have not see file,but is good to delete adaptations in the ecu,on my dyno when i delete adaptations it give me some extra hp
ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
mexanico1971 (15th August, 2015)
Afr is 13.0 across the board with my tuning and still I feel power lacking
This is your file...passw PM
Best regards Eddy
ecuconnection (11th October, 2014), scorpionreptyle (6th November, 2016)
I really hope you haven?t payed much for that crap
Its like one of these companys that just add a bit of fuel here and advance the ignition a bit there, raise the rpm limit and your ready...
typical pattern looks like this, and thats from your file:
They simply raised ignition advance by 2.6? over the whole rpm and load range.
Its all in the Damos file which is flying all over the net.
usually spark and fuel give better power. but real thing is to know how to mod the VANOS! wrong adjustment and it can get serious damage.
tuner pro+ hakenTT damos give good interpretations of the maps
What do you think about this file? LOL
BMW MS43Tuned.zip
i want to tune same MS43 but my 2.2 liter 170hp,have sense or not?
It can be tuned the same way as every other M54 engine. One just needs to find out the softwareversion of your file and get the right mappack. Building the mappack from the damos is pretty much straight forward but takes several hours to do so. If anyone here is familiar with disassembling by IDA Pro, we may work out something
US spec file? Have you tried that file? Be carefull as the ignition advance is somewhat advanced! Whoever made that file made a mistake in my opinion about trying to raise the rpm limiter I don?t think they took the right one
Did you made that file yourself? I?d start with raising Vmax
