Results 1 to 9 of 9
    Default q5 2009 tprot or not?
    i made a read out over obd from Q5 EDC17cp14 sw is 516613 is there a way how i can find out if this ecu has already tprot?
    carmageddon's Avatar
    Italy
    8R0907401J 0008 1037516613 tp active
  3. The Following User Says Thank You to carmageddon For This Useful Post:
    chriskross (11th October, 2014)
    thx m8,that means the only way to write back is bootmode.
    do you know which tp this ecu have?
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    Correct this file is tprot, if you write a moded file using obd mode the car will not start. The only way is in boot mode with a proper tool...
  6. The Following User Says Thank You to rappttor For This Useful Post:
    chriskross (12th October, 2014)
    Quote Originally Posted by chriskross View Post
    TP is V07.00
    Br.
  8. The Following User Says Thank You to gezame For This Useful Post:
  9. #6
    is the read out over OBD also protected, i will get the car again in one week and so i thought i can already remap the readout.
    is the file ok?
  10. The Following User Says Thank You to chriskross For This Useful Post:
    enricogalati (12th August, 2020)
  11. #7
    What do you mean just remap the redout ? You cant , it is TPOT 7..... unlock first
  12. #8
    Jul 2011
    I think he means prepare the file using the OBD read, ready for when the car returns
  13. #9
    Quote Originally Posted by bondiblu View Post
    yes correct that was what i mean
