sparedes (10th October, 2018)
Hello can someone provide a list of tools able to remoove completely FAP,DPF,AdBlue from cars below : BEST ECU READER ( FGTECH or KESS ........ )
Remaping programme ( ECUSAFE .....
DPF
VAG : AUDI Q7 VW TOUAREG( BKS BUN CASA ..) Ecu's
BMW : X5,X6 SERIE 3: E70 E72 E90 .....
Land Rover Sport TDV6 TDV8 From 2006 till now
Mercedes M164 M166 C203 C204 E211 E212 BOSCH And Delphi ecu's
Toyota : RAV4 CORROLA AVENSIS
AdBlue
Mercedes M166 ML250 ML350
Audi from Q7 Q5 ......
better manual solutions
Like what......
Swiftec)) ))
CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
Any liks for that?
let's split as you requested in two parts:
1st - you will need hardware to read / write the content of the ECU from/in the car.
here you have several solution and according to you budget you will find the proper solution on.
- complete MagProg package (MagPro base + X17 + BDM + BDM frame)
- FGTech last version
- CMD tool
- MPPS tool from AMT Cart Tech
- etc.
As I told you according to your budget you will find the proper solution for your needs.
2nd - software to "mod" the software readout from the car's ECU
If for hw tools you could find more or less complete solution from one supplier here up to now (according to my knowledge) you will not find something reliable and covering most of the brands.
But if you will go for an genuine tool - than most of the hw tools suppliers deliver also file service with a certain subscription fee / year.
The most important part for you in this moment is to define what budget would you spent in the very beginning for this issue.
regards
Farahidi (5th October, 2019)
your project will not be cheep man,too have all in one go.
to have all it take some time,or plenty of$$$$$$$$$$$$$$$
I think i will begin with some brands firstly AUDI and Toyota .. and then see if i can doo other brands
i think that for audi vw and toyota +other brands you can use bdm100 or fgtech for read-write on bench (even clones works fine),for read write the audi-vw until 2008 without problems you can use the clone of mpps,and for all brands use kess v 2.06 (can be used and for boot modality on bench)......for mod files best is winols(EVS) or
race 2000(DIMSPORT)....more practice is titanium from alientech......so,if you want to start your work with sommes clones until you will be able tu buy genuine tools,you must to pay 1000-1500 euro...good luck my friend
chakahafed (10th August, 2014), Farahidi (5th October, 2019), Hayssam1 (18th May, 2015), Siham (25th April, 2015)
Beware programs claiming to delete dpf from files. Many of these do not work correctly simply because there are so many ecu file variations, even for one manufacturer. It is safer to learn how to remove dpf yourself using a program like Winols. Then you know it has been done correctly. This is important because you will get many problem cars after dpf removal and you need to be sure that software part is correct.
There is no such thing as a complete software able to delete or mod all types of ecu files...the only correct way is the hard way: START LEARNING !
find damos, study files, use some of the crack software and study what their are doying well or not based on damos files, always use ols, buy good solutions test and study them etc.
regarding tools, any tool is good if you know how to use it. Personally i would recomand x17 package...
Swiftec doesnt work on all it says. Some cars still require manual solution.
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
