Give foto from ECU, or data from car
I have a job for the university, which is to tune an old fiat marea.
I know this is a mono motronic ecu, wanted to know what is the chip used? which chip to buy? and it have socket, or if I have to unsolder.
its like an old bmw 318is?
i think it is a 1.7.3, but I'm not sure that is it. how can I be sure?
the car is an fiat marea sx weekend
Open the ecu mate and upload a picture... You will receive much more answers
10720972_793722497337384_1719911030_n.jpg20141016_154837.jpg20141016_154656.jpg here are the photos.
eeprom is b58546?
can be replaced by another reprogrammable without having to use UV light to erase?
acrilio (17th October, 2014)
can you explain better?
my teacher said that the only thing I can do is read the chip and saved him.
so i need to buy another one to program.
if i can get new one 87c510, i can erase with UV light and program again, right?
that board is to solder in ecu? and than i do read and write on 27c512?
where can i buy that board?
for a student you are a little lazy !
for read a write I think you need one adapter for your programmer , and to convert UV latch eprom into electrical erasable like 27sf512 you need a sockt board to convert it .
https://www.google.pt/search?q=87C510
GrauTec -
learn to search
My work is my life ART TECH GARAGE
i make the board to convert the eprom.
this is the table map? begin - 0xAB00 end - 0xAC17
why this map's don't follow the rules? identifier, size of y, yy's, size x, xx's and then the table values...
for ex:
BF 1D is a map? BF 1D is recognized as a bosch map, but i think its wrong.
And the alleged maps that are after don't have axis?
the file:https://feupload.fe.up.pt/get/HR8TWFBCGKem2sO
