That is a hex decimal code. Try and get a OEBD code or a better scanner. In the meantime if I,m right it should be P00-68 throttle position correlation.
autoden
Got a valvatronic Mini stalling on cold start and running a little rough. has logged a code read with launch "2B68 air mass plausibility"
this car does not use an MAF sensor. not sure how this system works. how it calculates the Mass air flow and what would cause it to know it has a problem. and advise would be muchly apreciated.
Add life to your days not days to your life
P
autoden
Car also had stalling issues when hot.
Solution was very low engine oil. The slightly low oil pressure Affecting cam followers and valvetronic could not contr?l?e valve lift when nearly closed hence poor idle control when hot.
Purdy
P
parrot1964 (6th April, 2016)
If it’s low oil pressure ask peasant when last has oil/filter
as somehow there is a valve under oil filter, just lifts out. Non genuine filter not long enough to press it doon
