I need original full dump this ecu DELPHI DDCR 39101-4X740 sw: C7K63SA3 .
Thank you very much.
I need the same full read dump from 29F200BB.
Fec001 (9th October, 2015)
Yes, i know but tried to write the "tables" 40 kb file and ecu dead
upload both files or test this this is full file for automaticAttachment 335104
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Here are dumps. Full read after ecu crashed and only tables
Thanks!!! I was thinking about the same solution
File is ok I think, ECU can wake up (check engine light is on now) and can connect with diag but doesn't start. 1 DTC:
P1300 Injector classification
Control unit error
EDIT:
Injectors recoded, DTC gone but still no start...........
In measuring values no RPM and rail press while cranking.
With this dump, car can start but ECU reject injector coding. Idle at 1300 and no accelerator pedal.
DTCs:
P1300 injector coding
P1780 engine torque reduction
Any idea??
EDIT:
Found the problem. eprom 95080 is totally bad. Immo lamp doesn't light
CIRCUIT.FR (8th March, 2017)
pleas help me, I have some problem, read table flash 40 kb OK, write not.. got error, car dont start now, I solder flash out and read with programmer........ is possible got table files 40 kb and programmer files together for complete? Thanks for help
EDIT: I look for some software number, I compare files and not 100% some one block is missing, car show correct SW version but dont start, diagnostic show DTC 1300 o(
I try got this two files together ( crashed files from 29F200 and table read 40 Kb) Pleas control it that is OK, Car still dont start (Immo lamp dont light) Thank you
Use the complete file what I got from Icezero2010. Write with boot and teach in keys.
