Hi guys wonder if anyone can help? Keys lost, got new key from dealers but someone has changed ECU so pin code is not the same. So i need pin code for vin "wolotgf7018086656" thanks in advance.
autoden
autoden
Buy a I love you longtime carprog
read immo and you will get pin
OPEL / SAAB EDC15M * PSG16 * EDC16 * EDC17 * DENSO * ACDELCO cloning / programming / resetting
I concur read ecu with carprog , cryptoworks , avdi etc etc or read tms370 from immo aerial and get pin from dump
Today is the Tomorrow you worried about yesterday ......Was it worth it ?![]()
i agree with everyone above. AVDI & carprog will read them by obd. But I think cheapest way out is a cheap TMS370 readr & read the immo unit & opcom to relearn the keys, thats how I used to do them before I got some more expensive equipment.
hope this helps![]()
It will be pointless reading code from TMS370 if the ECU has been changed, carprog the only solution I can think off.
Carport iShit fail. B&b bb. N. Cheap enough. Think buy ebay
Not having used carprog or the likes before i would be at a disadvantage, but i wil look into it for future reference. customer is going to beg main dealer for another car pass. Good luck to him with only vin to go on.
autoden
if the car was running before the keys were lost reading the tms chip will work as it would have to be matched to run car previously
i think THE OP means the ecu kit was from another car so pin wont match vin ? please correct me if im wrong .. but if car was running but had an ecu swap it still needs tms in arial matched to ecu (decoder ) to run
so if it was running before keys were lost you will still get pin code from the immo box
super jumbe (19th October, 2014)
As for pin from vin only, nil poi. Not even moderators can do it now
Had a look today at carprog, ordered and on its way. The car was running until keys lost. Some time ago ecu, dash and reader were replaced. So carpass was only good for key cutting.
autoden
unless your doing keys etc everyday wouldn't it have been easier to call someone else![]()
I am a FUD
As I stated, the owner is trying to get a carpass from main agents using only the vin. The car has been parked up for 6months, so no rush.
autoden
carprog plugs into dlc and gets pin from ecu, no hassle. Op-com reads eeprom from cluster, also by OBD plug. Reading tms 370 from antena will give you the pin as well. Lots of choices....
Yesterday we stood in front of the abyss. Today we'll move ahead.
If you need any repair manual, pm me- maybe I can help you.
If I were you I would just go to scrap yard and do exactly what the last person did, buy the full kit, being an old car the full kit will be around ?60 and save the hassle.
1 carprog ?40.00, Pass from dealer ?30.00, new keys ?30.00 total parts ?100. You will still have to buy ID40 chip and key programming tool…..cheaper to buy another car.![]()
