Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 91
  1. #61
    Aug 2018
    Romania
    Now, you can use the two options I mentioned above.
    "we can modify in eeprom to take the values from the CAN, or you can make the physical modification, on the wires to "pass over" the tachograph"
    For eeprom, you should reread it now, after you have disabled the tachograph
    Do not forget to press Thanks and Reputation buttons!
  2. #62
    Jun 2019
    I prefer the ecu solution cause my speed sensor in the gearbox is broken.
    You can find attached the new dump,
    Thanks a lot
  3. #63
    Aug 2018
    Romania
    Try this.................
    This is the only solution that i know.
  4. The Following 4 Users Say Thank You to sebage For This Useful Post:
    Algerkov (20th May, 2022), Johnner (19th May, 2022), spamme0815 (17th April, 2023)
  5. #64
    Jun 2019
    Thank you, i try this tomorow.
    Edit : Hello man, it's perfect, all is working perfectly, you saved my life !
  6. #65
    Jul 2022
    Привет всем. Если я сначала запишу исправленный дамп и только потом отключу тахограф, спидометр будет работать?
  7. #66
    marina_rv's Avatar
    Ukraine
    Quote Originally Posted by dimoonn2 View Post
    !!! only ENGLISH forum !!!
    please press the little THANKS
  8. #67
    Jul 2022
    ok.
    Hi all. If I first write a corrected dump and only then turn off the tachograph, will the speedometer work?
  9. #68
    Aug 2018
    Romania
    You start with the beginning.
    Disable the tachograph with VCDS and then see what works and what doesn't.
    (And by the way, if you turn off the tachograph, what sense would it make to keep it connected?)
  10. The Following User Says Thank You to sebage For This Useful Post:
    dimoonn2 (11th July, 2022)
  11. #69
    Jul 2022
    The car is far away, the dismantled dash is now on my table, I want to fix the dash and then go to the car and finish the rest. Here is the original dump I read.
  12. #70
    Dec 2015
    VW T5 2005 2.5 Tacho off 7H0920851R7H0920851R tacho.rar7H0920851R tacho.rar
    Good afternoon guys, help me solve the same problem. You need to remove the tachometer and make sure that the speed is read via CAN BUS. I am attaching the dump.
  13. #71
    Aug 2018
    Romania
    You have to physically remove the tachograph, then first time you need to remove the tachograph from the instrument cluster. With VCDS, adaptation, channel 33.Then, IF the speedometer and fuel indicator will not work, we can modify in eeprom to take the values from the CAN, or you can make the physical modification, on the wires to
  14. #72
    Dec 2015
    I have already done all this. I need to fix EEprom under CAN.
  15. #73
    Dec 2015
    Thanks, I figured it out myself!
  16. #74
    Nov 2019
    Austria
    Default remove tachograph
    hello, can someone please prepare eep for me?
    i set channel 33 to 0, the "T" is going away.
    then i read dash with vvdi2
  17. #75
    Aug 2018
    Romania
    I don't know if you chose the happiest solution, to read/write with VVDI, your reading is swap bytes.
    I assume that km are already visible on the display.
    You have here the adjustment for information via CAN.
  18. The Following User Says Thank You to sebage For This Useful Post:
    marioscheiber (24th August, 2022)
