Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 91
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Default VW T5 disable tachograph
    Hello to all.
    I have a problem with 2007 VW T5 and need to remove tachograph from instrument cluster.
    Speedometer not work, and temperature move up and down.
    Dash - 7H0920851R
    Please help me!
    Best Regards!
  2. The Following User Says Thank You to konq100 For This Useful Post:
    Gagik1984 (20th May, 2017)
  3. #2
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Not seen tacho in this cluster before can it not be done in coding with vagcom
  4. The Following User Says Thank You to teerak2uk For This Useful Post:
  5. #3
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    I reed dump after make adaptation with vcds (33 chanel, trip logger - 0). I not have dump before coding procedure. The big "T" and ---- on cluster is gone, but speedo and temperature not work. Please help
  6. The Following User Says Thank You to konq100 For This Useful Post:
  7. #4
    Aug 2012
    outerspace
    Vag com will sort this out its in adaptions
  8. #5
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Adaptation not work for me. I need tacho off dump.
    Dashboard - 7H0920851R
  9. #6
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Problem solved. Thanks!
  10. #7
    mcd76's Avatar
    Apr 2012
    BT Romania
    Quote Originally Posted by konq100 View Post
    are you telling us how you did it?
  11. #8
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Quote Originally Posted by mcd76 View Post
    You have pm, mate.
  12. The Following User Says Thank You to konq100 For This Useful Post:
    mcd76 (21st October, 2014)
  13. #9
    Mar 2010
    WW
    same trouble i have after disable tacho in t5 with vcds, i solved by cloning parts of dump from original dump and dump without tacho, this is all my try
  14. #10
    Jan 2010
    HI!
    I have a similar problem.
    Please help me!
    thx
  15. #11
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    please remove tachograph from dash
    VW Transporter T5 2003
    7H0 920 851R
    VDO - VWZ7Z0F
    6N0909901
    sw: T5V02
    93c86
  16. #12
    mcd76's Avatar
    Apr 2012
    BT Romania
    Quote Originally Posted by audiopoint View Post
    7H0 920 851R
    VDO - VWZ7Z0F
    6N0909901
    sw: T5V02
    93c86
    try this friend...
  17. The Following 6 Users Say Thank You to mcd76 For This Useful Post:
    ampibali (3rd July, 2023), audiopoint (14th October, 2016), condorneck (6th October, 2017), jurarovne (19th January, 2019), mbedv (30th November, 2017), McDowell (16th July, 2024)
  18. #13
    Sep 2010
    Adaption 33-0, Disconnect tachograph. Plug yellow/ black wire B1-100ohm resistor 12v, B2 red wire ground, B3 brown wire speed signal to B8 white/blue wire. Thats it.
  19. The Following 8 Users Say Thank You to vagdiag For This Useful Post:
    artur12 (15th February, 2017), d.zio (5th November, 2016), H2Deetoo (1st November, 2016), impuls002 (26th September, 2019), Pablo98 (15th May, 2018), tiguan (2nd November, 2016), Tzepy (3rd September, 2018), vladgsm1 (2nd January, 2019)
  20. #14
    Mar 2016
    Hi.Need remove tachograph from dash
    VW Transporter T5 2005 VDO v03 93c86
  21. #15
    Mar 2017
    Hey guys I want to remove vw t5 tachograf
    I have adaptate dash but to change dump
  22. The Following User Says Thank You to Gagik1984 For This Useful Post:
    Berta01 (6th November, 2020)
