Bump... Nobody ?
Hi any kind fellow member help me please ?
i tried volta to DPF / EGR off, and i still had Dtc, and dash says regen dpf urgently etc,,,,
i had a file made manual soloution, i still had dtc for egr, but no lights on dash, today garage says light on dash,
DPF again,
anyone help, EGR off and DPF off, Manual soloution / please ,
must we blank egr ? or can we just use mod file,
Thanks mates
orig / DPF/EGR407-edc16.rar manual solution enc
Bump... Nobody ?
HI , DPF OFF+ EGR OFF FOR YOU.......
nylm (27th February, 2019)
remember manual solution requires sensors working and conected. sometiems a DPF reset is necessary in ecu and BSI
Tuiken (5th June, 2016)
thanks for your file, now we have No Dpf still egr issue (plugged in or unplugged) new x 2 dtc codes 1728 can comms permanant fault, and ESP light on, u1208 comms with engine ecu, in abs/esp,
had this issue before on a 206cc same engine, lexia sorted , but cant go in as have can comms issue,,
ANYONE ??? help
did you tried to use ecusafe?...for french cars work 80%
diagprog (28th October, 2014)
No i never did, will try next time more concerned esp light on,,,,
I still have a issue with this car p1728 can engine torque inplausible, autocom wont clear, (permanant)
i have Diagbox but not sure where to look to clear, any one help please very urgent, can i virgin ecu and start again ?
or diagbox where do i look ?
resolved, EGR disconnected, unknown to me , hence couldnt clear code 1728. re connected put another dpf egr off file (proper) cheers omnicru
Check the power supply EGR valve from the ECU to pin 3 after switching 12V and pin 1 after switching 5V. If you do not have 12V on pin 3 is a bug in the ECU. After disconnecting the EGR valve was not in the ECU error
When you turn off FAP filter when DTC is related to incur in BSI exchange FAP filter and reset values additives and achieve low levels of additives supplementing that was all without DTC, is not enough to make regeneration
managed to remove code with diagbox relating to ESP error, plugged egr multiplug in and cleared code, would not let me before, all ok now, thanks
