is there also a possibility to get newer firmware as well?
Thanks.
Thanks.
gavi23 (5th April, 2021)
Does anyone know if steering wheel controls work after can gateway update with RCD330? Car is Seat Altea 2005.
Sent from my Redmi Note 4X using Tapatalk
hi,
i don't have privileges to download this file.
Can someone share some external link?
hello,
Test Test Test Test
hy.
could you send me pm
pls
hy . i do not have privileges to download this file.
Can someone share some external link? THX
Hi guys,
I cant find a flash file for Passat Gateway with index __0178. I only can find 1k0 ....__0178.sgo for Golf gateways. I have to update my gateway 3c0907530C from passat, i installed a RCD510 and have battery problems.
Thanks fo any help
Hi! Can you send me this firmware ? Thank you!
Please files gateway 1K0907530K ver.0178. Bin? Please thanks
For made update of unit from RCD300 to new unit RCD330 Plus unit China version, I update can gateway for Golf V 1.4 2005, from original 1K0907530E to 1K0907530K 0178.
When I turn off unit RCD 330 Plus, I have 0.4 A consumption current, the consumption current need to go at 0 A, but not go and I have only 0.4 A also after some minute.
The current I measure directly on Fakra connector on cable what go in unit at pin + with DC A Clamp meter Fluke.
Know some one if can do update to 7N0 907 530 AM or 7N0 907 530 AN from 1K0907530K 0178, or frorm 1K0907530E ?
Have some one 7N0 907 530 AM or 7N0 907 530 AN sgo file ?
I find some information, need to change Gateway module, but I think can made also update.
See this for RCD330 Plus https://icdn2.pushauction.com/0/0/b0...104a3ca484.gif
Hi!
Thx your help!
