Results 1 to 10 of 10
    Mar 2010
    EU
    Default Help change km Peugeot 407
    Hi friends,
    i need help with Peugeot 407 2008y 2.2HDI
    original 346383km need 137000km
    BSI Johnsons Controls eeprom 95128
    Thank you in advance
    Oct 2012
    write all bsi FFFFFFFFF then recode all bsi with diagbox
    the file for dash is here...
  3. The Following User Says Thank You to betrescudan For This Useful Post:
    icar (19th October, 2014)
    mastaflex's Avatar
    Jan 2009
    FR47310
    Quote Originally Posted by betrescudan View Post
    i don't think it's good solution . it will just result with 999999km in dash and coding not possible
    Sep 2009
    here u have
  6. The Following User Says Thank You to mb7361 For This Useful Post:
    icar (20th October, 2014)
  7. #5
    Oct 2012
    Quote Originally Posted by mastaflex View Post
    bsi johnson controls making FFFFFFFF all eeprom means vergine...then recode with diagbox....sollution tested
  8. The Following User Says Thank You to betrescudan For This Useful Post:
  9. #6
    Mar 2010
    EU
    thank you for your help betrescudan
    what about immo key? Do i need pin code and learn key?
  10. #7
    Oct 2012
    you use the pin code original...did you have the pin?
  11. The Following User Says Thank You to betrescudan For This Useful Post:
  12. #8
    Oct 2012
    Quote Originally Posted by icar View Post
    your pincode is NEJS or SJEN for vin VF36ERHRJ9L010068
  13. The Following User Says Thank You to betrescudan For This Useful Post:
  14. #9
    Mar 2010
    EU
    This car is full with extras about this i am afraid to virginize BSI and code again.
    mb7361 files are ok. Thank you again all of you
  15. #10
    Oct 2012
    with diagbox you can print all parrameters of bsi...then recode with same ....regards
