Results 1 to 4 of 4
Thread: EPG enigma
    Oct 2014
    Default EPG enigma
    I have nearing the end of the line with this Vu+Duo, and am wondering if anyone has the time to rescue me.
    I'm fairly au fait with much of anything that resembles the 'user' side of typical software, but this has been a big challenge. To explain, so far I've switched between Vix and BH (flashing) in an attempt to find the most direct route to mastering the EPG set-up, am running VuCC (and a spare non-designated FTP prog), viewed my Vu drive remotely through the Web control of VuCC and got as far as capturing screen shots of same.......but no matter how many options and software triggers I try, I fail, and I'm still looking at a channel list without a bouquet involved - the windows equivalent of DOS.
    This site is my last chance......if not, anyone want to make an offer on a Vu+Duo with half a TB of memory? (unused)
    digicon's Avatar
    If your trying to setup EPG and have the latest version of Blackhole installed then you will need to set CrossEPG up in the settings menu, if CrossEPG is not installed then download it from the Plugins section latest version is 0.8.1 i think.
    As for the Frontend i do know that Blackhole EPG format is not the best looking so you could also install Coolmans EPG which is used as the frontend Gui for Crossepg
  3. The Following User Says Thank You to digicon For This Useful Post:
    Plumpudding (30th October, 2014)
    Oct 2014
    Why thank you.......I'll try that
    Oct 2014
    Was cracking on with it, but apparently my 'magic number' was wrong......
