Hello
Could be 6750000/X in 16 bit LOHI?
I think it is M1.1 ECU.
Hello guys
I am looking the rev limiter factor for this old motronic 1.3 ecu.
I have tried all ready 912500/X but it makes no sense. Does anyone has any idea?
Just to help you rev limiter 1 is at 62c4 and number 2 is at 62F0Bmw 320i 1989 E30 0261200152-1267355487 ok.rar
Hello
ECM Titaniun show factor 6750000 .
I think that it is wrong Vasily
It is quite easy multiply the rev limiter value (320 usually around 6500RPM) with F4h(244), you get 1586000 this is the scaling factor.
Why wrong?
@Vasily: The result of this factor is 27663.
@easytech: It seems that that its the correct order.
If somebody knows the correct answear and its 100 sure, please post
27664 in 8bit mode, but need 16bit LoHi
For example rev.limiter 7500
BMW 320I 1989 E30 0261200152-1267355487 OK_7500.rar
Oh i see Vasily.
Unfortunately i will tune this with tuner pro and i can't figure a way to do it LoHi... Do you have any ideas?
I'm not use tuner pro, but i think like this
