Can anyone help me, trying to read HC05 mask 0D62J QFP64, with xprog, mcu is from 1998 mercedes sprinter.
xprog says device is silent, I try with power supply too.
Any diagrams or settings would be great.
Thanks in advance, ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
Did you set oscilator to other value like 8000000?
I tried that, it was set to 16mhz, i changed to 8 but still same
ninja
Remove MCU from board and solder to qfp64 adapter and you can read it without problem.Dont waste time to try read it onboard with xprog.
friend if you got message device silent on first time that mea your chip is errased.xprog not good tool for this mask.best tool is etl705
Last week had same immo box and just removed mcu from board and job done in few minutes.Xprog skip security bytes and dont erase mcu.
with that mask I have problem to when I tray to read it with xprog so I use etl clone
Siham (1st November, 2014)
hello
xprog can do it 100%
but it better to buy adapter
I use it dailey
i have removed mcu and soldered to adapter but still xprog will not read it, can anyone give connection diagram or any other info that i need to use xprog to read this bitch?
ninja
Did you solder xtal 8000 or 16000 MHz to adapter near mcu?Without xtal you can't read MCU.
Which adapter you use?
You must use this adapter
IMOBILIZADOR SPRINTER 0j66D MC68HC08AZ32.JPG teted 10000 ops , 0d69j 62 ak400
That is not solution for hc05.
You must get this adapter when buy xprog device.
Here is pic with marked pins for xtal,but soldering is from other side of adapter.Try and you will see what is magic of read/write hc05x16/32 with xprog.
And guys,if this helpful dont be shame to hit thanx button![]()
obdsystems (2nd November, 2014), zecozc (18th June, 2016)
