Results 1 to 9 of 9
    seba_m_'s Avatar
    Default Audi edc17cp14 problem after modification
    Hi guys, can someone look at the correctness of software modifications? The problem is that in the higher gears slipping clutch. The clutch is driven 25,000. Audi A4 B8 2.0TDi CR EDC17CP14. The original software problem does not occur.
    Babos's Avatar
    Mar 2012
    it can be clutch problem!
    But try less torque and check slipping or no.
    Mod file look good but i look just maps no data but see that must be good job.
    seba_m_'s Avatar
    Only the original file that does not exist. And you can help reduce torque?
    I think problema is in mod file.
    Br.
    seba_m_'s Avatar
    it will help someone solve the problem ??
    Oct 2012
    Quote Originally Posted by seba_m_ View Post
    i think this will be better
  7. The Following User Says Thank You to betrescudan For This Useful Post:
    seba_m_ (2nd November, 2014)
    seba_m_'s Avatar
    Thanks friend. I'll check on and give a report.
    seba_m_'s Avatar
    It is much better but still on the 4th gear clutch slipping. On Friday, I assume a new clutch and I will inform about the results. Thank you all for your interest in my problem and the resultant help.
  10. #9
    Oct 2012
    clearly sommes problems with clutch...with a new one,you can return to the old remap...regards
